brake upgrade
Old Apr 20, 2009 | 04:53 PM
ben240sx's Avatar
Question brake upgrade
whats the cheapest way to do a bigger brake upgrade or atleast the best way to do it and which are the best rotors to go with
Old Apr 20, 2009 | 04:57 PM
go to the junkyard and get the calipers from a 1984 oldsmobile cutlass and they should bolt right up
Old Apr 20, 2009 | 05:04 PM
Evans1109's Avatar
Old Apr 20, 2009 | 07:54 PM
240smoke's Avatar
HAHAHA. Tired of people not searching the forums??
Old Apr 20, 2009 | 10:31 PM
fadedsilvia's Avatar
i hear the 92 chevy suburban rotors fit perfectly in there as well
Old Apr 20, 2009 | 11:19 PM
dude thats obviously overkill you will lock up the wheels too easy and would be worse.
Old Apr 22, 2009 | 04:28 PM
ben240sx's Avatar
so a cutlass or a suburban will be good same calipers though or gotta get everything.... i have a jdm 5'' tach with oil pressure water temp and oil temp wucha think should i put it on....
Old Apr 22, 2009 | 09:33 PM
just the caliper and the rotor
Old Apr 22, 2009 | 10:11 PM
USMCDrifter's Avatar
My Bullitt comes from the factory with 13" rotors up front and 12 inch rotors out back . . .I'll sell you my original rotors with calipers.
Old Apr 23, 2009 | 12:38 AM
well i didnt tell him about the Bullitt option because its generally more expensive and overkill for a 240
Old Apr 23, 2009 | 04:11 PM
Evans1109's Avatar
JDM YO put it on
Old Apr 23, 2009 | 05:33 PM
I have to wonder, why do you even WANT bigger brakes?
Old Apr 23, 2009 | 06:06 PM
what good is power if you cant stop?
Old Apr 23, 2009 | 06:49 PM
what power?
Old Apr 23, 2009 | 07:06 PM
the power being generated by the jdm 5'' tach with oil pressure water temp and oil temp gauges and what not.
