brake upgrade
whats the cheapest way to do a bigger brake upgrade or atleast the best way to do it and which are the best rotors to go with
go to the junkyard and get the calipers from a 1984 oldsmobile cutlass and they should bolt right up
(Post 385373)
HAHAHA. Tired of people not searching the forums??
(Post 385373)
i hear the 92 chevy suburban rotors fit perfectly in there as well |
Originally Posted by fadedsilvia
(Post 385393)
so a cutlass or a suburban will be good same calipers though or gotta get everything.... i have a jdm 5'' tach with oil pressure water temp and oil temp wucha think should i put it on....
just the caliper and the rotor
My Bullitt comes from the factory with 13" rotors up front and 12 inch rotors out back . . .I'll sell you my original rotors with calipers.
well i didnt tell him about the Bullitt option because its generally more expensive and overkill for a 240
Originally Posted by ben240sx
(Post 385479)
I have to wonder, why do you even WANT bigger brakes?
(Post 385519)
what power?
the power being generated by the jdm 5'' tach with oil pressure water temp and oil temp gauges and what not.
| All times are GMT -7. The time now is 01:01 AM. |
