Diff question
Old Feb 25, 2009 | 10:46 PM
smoken805s14's Avatar
i have a 96 24osx se and i was wondering if i could swap the diff with my new 90 240sx....and if i can how hard will it be?
are diffs the same size?
Old Feb 25, 2009 | 11:10 PM
-no you cant swap them due to the half shafts/ABS ( if applicable )
you could change them out internally only if the diff on the s14 happens to be an R200. An R200V is a Viscous lsd
-the housings are different so they cant mount to each other
its not hard at all
if you look at my write-up, you will see the process involved
http://Biggamehit.TeamMNR.com
also what type of 240 do you have?
Hicas model etc etc etc
additional reading for you
http://en.wikibooks.org/wiki/Nissan_...n/Differential
Old Feb 25, 2009 | 11:25 PM
oh okay thanks...my s14 has the stock lsd for the se edition....and i got an open diff on the s13...i guess i'm goin to have to buy one now....welding the diff doesn't work that well does it>? (for drifting purposes)
Old Feb 25, 2009 | 11:35 PM
yes its great for drift purposes. many will argue that it disrupts other things.... yes it does, but if you learn to deal with it until you can get a 1.5 or 2way diff, it will be fine. a 2way gives when under decel which is great for racing, however a 2way is just as jerky when daily driving as a welded is.
smoken805s14
May 2, 2009 08:01 PM
coleysanderS14
May 14, 2007 02:36 PM
socaly4life
Dec 28, 2004 03:54 PM
rudeboy
Dec 26, 2002 04:51 PM
