-   How To Requests / Questions / Tips (https://www.s-chassis.com/forums/how-requests-questions-tips-49/)
-   -   Lights come up wont go down (https://www.s-chassis.com/forums/how-requests-questions-tips-49/lights-come-up-wont-go-down-42070/)
Whattup32526 Nov 18, 2007 06:25 AM
My headlights come up but dont seem to want to go down unless I turn them down manually....what should i check ? All relays and fuses are good already changed them....could it be the headlight timer?? on the drivers side around the fuse panel?? anything you got let me know thanks
onikyan Nov 18, 2007 09:39 AM
i had a couple that did that to me. one turned out to be the fuse and relay panel on the driver's (left) side. the other turned out to be the actual headlight switch that's on the steering column. if you're good with a multi-meter then you can track it down quick with that, if not then it's all trial and error with replacing parts here and there. good luck with it though
Drift Motion Nov 18, 2007 02:50 PM
does the headlight button work?
g3bio Nov 25, 2007 07:14 PM
i fixed this problem today actually it was a fuse that was under the hood in the box beside the coolant tank. not the small fuses one of those square long fuses.
you said it was not going down but usually for saftey reasons the headlights go up when a fuse is blown double check that and make sure its a brown 25 amp fuse with a clear top, you dont even have to pull it out.
Now when you install it make sure that the lights are on when you put the fuse in (and up) otherwise it might blow again,,, thats what happend to me today dont ask me why my buddy just told me to do it and it worked.
hope that help.,s
RuizXIII Nov 25, 2007 08:11 PM
Yeah check the fuses. Those headlamps can be a real pain.
Whattup32526 Nov 25, 2007 08:21 PM
cool ill check it first think in the am....i start a new job tommorow... yay!!
