-   How To Requests / Questions / Tips (https://www.s-chassis.com/forums/how-requests-questions-tips-49/)
-   -   Need help with heathing problems... (https://www.s-chassis.com/forums/how-requests-questions-tips-49/need-help-heathing-problems-45217/)
napor Jan 10, 2009 11:40 AM
I dont knwo if this its like a 240 thing but i had a 92 and a 89 s13 wich i had the same exact problem with the one i have now, i live in mass, so it gets kinda to cold up here by winter time. and so far i have no other car but my 240. now i have a 93 s13, that it takes forever to warm up, i turn it on for like 15 to 20 minutes to warm up a lil bit, and the heat in the car its not as hot as i would like it to be its just warm, some ppl told me that its the thermostat, so i was wondering if its that or something else cuz like i said i had the exact problem, with my other 2 240's that i had thanks....
jramosthe1st! Jan 10, 2009 12:11 PM
it could be that the thermostat is stuck open. i assume if you've been told what the problem might be they also told you how to check it so i wont go into that. a quick fix remedy is to get a piece of card board about the size of the radiator and slide in between the ac condenser and the radiator core. it's not the best solution but a quick one that will work until you replace the thermostat if in fact that is the problem.
Biggamehit Jan 11, 2009 01:03 AM
yeaup.. replace thermostat and bleed the system. check for any leaks inside of the car under the dash on the passenger side.
napor Jan 16, 2009 04:19 PM
Thanks guys, that helps me a lot in my car, and knowledge too!!
Evans1109 Jan 16, 2009 07:45 PM
[QUOTE=Biggamehit;378572]replace thermostat and bleed the system. QUOTE]
Don't forget this part. Had a friend that skipped that step and had a air pocket stuck in the line, lets just say he was overheating and then cursing in the end.
Biggamehit Jan 17, 2009 12:46 AM
yea... the FSM also suggest that you raise the front of the car slightly/evenly while bleeding.
