Tranny Problem Sr20det
hey guys, i just swapped my s14 automatic ka24 to a Sr20det 5-spd everything was ok but the tranny mount braket is not fitting in its position, if your looking from the back of the car it comes from right to left making an L shape, so you cant turn it, and the screw holes dont align when i turend it and aligned the holes the tranny mount bracket was sitting slanted causing the engine to lean to the right. What should i do,?? i been looking for an item to buy like the bracket or so but i found nothing...
are you using a manual tranny mount.. you have to
also make sure its not backwards. |
i got it
i fixed it and cut the engine on after a 5 months wait and $7500 spent and the block is ****ed up,. clicking noise going nutts, the warrenty is over and i dont what to do?? can i take the mothf-ka to court.
damn bro wth happen....... 7500 for what?
2 engines, and extra part's for the engines.... we're calling the guy tomorrow, he also gave us the wrong ecu with one of the engines so technically it's their fault =)
