300 ZX Brake Swap
This is the best site i've found for doing the 300ZX brake swap, step by step with pics. I was gonna copy and past it, however we'd have to reference all the pics. Definately a great help.
300ZX BRAKE SWAP WALKTHROUGH Dr. |
Good find :thumb: Gonna start my Z32 brake swap soon and this makes for a great resource.
yeah the rear is the trick...i want the 300zx uprights cuz they are aluminum...i also want alumium calipers but my S15 ones will do.
Found Another one, hope this helps! Makes me want 300zx brakes, I loved how they felt on my buddies s13, I HATE my stock s13 brakes. Hopefully the brembo rotors and axxis pads will help.
Another 300zx Brake Swap Walkthrough Dr. |
Bleed the brakes and put in new fliud, along with the rotors and pads u should have better stoping power:thumb:
how often do you need to change the stock calipers? how do you know if they've gone bad? i read on the midas site that if you have screetching, the calipers may have gone bad... any input?
SO what's better aluminum or Iron brakes? 26mm or 30mm?
Ligther? Heats up faster? Brakes better? What's the deal? |
I have been thinking about swaping out with a z32 but what are the addvantages over stock 240 brakes? Do they perform better? (i like em because the say Nissan on em!!:naughty: )
Just paint em red.
what is the minimum rim size can you go with? how well do the zx wheels fit? I plan to drill the front rotor to make them 4 lug.
Thanks, Sid |
