How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
unsticking stuck lifters
Old 06-24-2007, 05:22 PM
ok guy here is what you've all been waiting for.
tools needed
1. small pick and flat head screwdriver
2. easy out
3. pliers (maybe)
4. patience
1. you'll need to look closely but you can see that lifer has a clip holding the cylinder from falling out. this is the hard part, i got lucky and removed the clip in about 2 min. but spent about 15 min trying to take another one apart.
with the pick or screwdriver remove the clip.
4. clean out the inside of the lifer.
i used this stuff called b'laster, and some break cleaner just spray some in the cylinder put the spring back in and squeeze it a few times then put some fresh oil in and reassemble.
this can be done fairly quickly but it can take all day. it just depends how fast you can take the clip off. also i soaked the lifters in diesel for a few days before i took them apart.
maybe next time i'll show you how to make solid lifters. i haven't made any yet but i have it all in my head.
jramosthe1st! is offline
Old 06-24-2007, 06:06 PM
Wow good work bro A+++
Biggamehit is offline
Old 06-25-2007, 10:46 PM
i forgot to mention something.
before you put the lifter back together take the spring off the little relief valve. spay your choose of penetrating oil into the larger of the two cylinders then put them together her and squeeze until the relief valve it unclogged. otherwise air will get trapped and cause a vacuum which will lead to your lifters sticking again. then just install the lifters and go through the bleeding process as recommended in the fsm.
Old 06-26-2007, 03:32 AM
dude use the lil flower close up mode
Old 06-26-2007, 06:17 AM
got it, i was wondering what that was for but never bothered reading the manual.
also i'll go back and redo my first post to include all the steps with better pics when i get a chance.
Old 12-01-2009, 05:31 PM
hey Jram can you rehost those pictures.... Im helping a fellow 240 buddy with this possible issue.
Domo
Old 12-01-2009, 09:52 PM
give me a day or two, i have to dig up a lifter and take some more pictures.
Old 12-02-2009, 06:48 AM
Roger that
thanks bro!!
Old 12-10-2009, 04:43 PM
i apologize for not getting the pics up sooner, i've been busy.
Old 12-16-2009, 10:07 AM
fadedsilvia's Avatar
would this help a noisy valve train issue?
fadedsilvia is offline
Old 12-16-2009, 10:38 AM
absolutely.
my lifters rattled so bad that it sounded like i have marbles under the valve cover. after cleaning them out and going through the bleed out process as described in the fsm, all that is gone. although the dohc lifters are different though and am not sure what you would need to do about them. other than pouring a quart of atf in the crank case and hope that works.
Old 12-16-2009, 02:29 PM
ill look through my fsm an see if theres a bleeding procedure an all that stuff but i dunno how different they would really be there still hydraulic lifters
or maybe its like any other project I start were nothing goes according to plan and theyll be completely diferent
Old 12-16-2009, 03:07 PM
yep.... completely different
vortxxe
05-02-2006 06:58 AM
nsn240
12-17-2005 09:05 PM
sicphuck
10-04-2005 05:52 AM
Shark_MegaByte
05-04-2005 12:10 PM
nissanrydin
03-23-2004 03:07 PM
Quick Reply: unsticking stuck lifters
