Clutch replacement
so i have a quick Question.
i Have an S13 HAtch with a VQ35de and the throw bearing is just about to give up (its pretty loud) and needs to be replaced, now i've replaced several clutches and dropped a lot of transmissions but lately ive been getting kinda lazy therefor my VQ swap was done by someone else and i haven't really done any major work on it cause it's been running pretty dam good, ok now to my question. has anyone replaced the clutch on their vq swapped S13? is it easier to pull the engine/tranny as one piece or can you just pull the trans like a "regular" clutch replacement procedure with no major headaches? I ask because as you know that 350z trans is much bigger than the stock 240sx trans... Any help is much appreciated. |
