Creating/installing Solid Motor Mounts
ok simple DIY if you have the time. I was going to pick up some nismo solid mounts, but i figured i would just make my own, very simple
Materials s13/s14 motor mount ( s14 mounts bolt hole is slightly more forward then a s13's mount) 3m Window Weld Caulk style gun tape 17mm wrench 14mm wrench 14mm socket 12mm socket 3/8th extension Creating Solid Mounts ----------------------- http://img169.imageshack.us/img169/8...pim0446zf1.jpg -apply tape like so and then fill the mounts up, you want to make sure that you have no air pockets. you can use any kind of straight edge such as cardboard to force the window weld into place http://img486.imageshack.us/img486/9...pim0447ww1.jpg -finish product.. now allow to bake in sun for at least 2 hours and then you can move them inside and let them sit for at least 2 days to fully cure. http://img475.imageshack.us/img475/4...pim0449yv2.jpg Installing Mounts ------------------- -Start by jacking the front of your car up and giving yourself space to move around below -remove the 14mm nuts at the bottom of the mount. on the driver side use a 14mm socket and extension. On the passenger side you can use the closed end of the 14mm wrench http://img521.imageshack.us/img521/8...pim0476va2.jpg http://img528.imageshack.us/img528/1...pim0481uh7.jpg -remove the upper nuts from the mounts on both sides http://img516.imageshack.us/img516/5...pim0482zm9.jpg -Proceed to your transmission mount and remove the bottom two nuts to give yourself extra clearance http://img516.imageshack.us/img516/7...pim0483do4.jpg -Place jack in this position and raise to remove mounts. if you need more space refer the the second photo below this text. http://img524.imageshack.us/img524/6...pim0484gf2.jpg http://img294.imageshack.us/img294/6...pim0485sl9.jpg. -remove mounts http://img507.imageshack.us/img507/2...pim0486ns4.jpg -insert new mounts and make sure the L and R on the mounts are facing you for proper installation. when you are putting the mounts in. follow the motion that i did. this will allow the bottom section of the mount to clear the Crossmember and drop in. Once the mounts are in position, with your hand, screw the 14mm nuts on the top and bottom of the mounts this will hold the mounts in place somewhat so that when you lower the motor back down. it will fall into place http://img204.imageshack.us/img204/5...pim0487us7.jpg http://img467.imageshack.us/img467/7...pim0490on4.jpg Bonus Material on the driver side you will see these two lines.. well i don't have power steering and i cut the lines off inside the engine bay a while ago. you could do this to shorten the line and leave your engine bay looking more cleaner. the reason that this is important is, you want to keep a certain amount of fluid in your Rack n Pinion becuase if it drys out you will need another one. http://img359.imageshack.us/img359/2...pim0474qw5.jpg cut, hammer, crimp http://img124.imageshack.us/img124/9...pim0491fu3.jpg PS i know my undercarriage is filthy.. ill clean it when i get back from Iraq http://img211.imageshack.us/img211/7771/coolaidaq5.png |
that's cool. I've heard of people buying hockey pucks and drilling holes in them to make solid mounts lmao.
ohh yea.. thats a old school hot rod trick..
:thumb: sweet bro let me know how they work out
not bad....but i still think my write up is better. :pimpflash:
i'm kidding, it's always good to know more than one way of doing things.:wave: |
you did one bro.. i didn't see it lol
yea all i did was took a set of near new oem mounts and filled it in. |
i did one with cusco mounts. the installation process was different but like i said the more options you have the better. :thumb:
i didnt see it posted
So, how much did it help?
Nice write-up man! How does it feel or sound now?
awesome took it out last night.. and the transition coming from a hard corner is awesome now.. no violent snap backs.
lil vibration at idle. but thats normal for somewhat solid mounts. the window weld has a slight bit of give so that help absorb some of the kinetic energy |
hockey pucks.
(Post 334061)
na bro.. its no issue with it.. only thing is you may have to double them up or use some big washers because one puck would lower the motor and put you at risk of slamming the oil pan.
I have been running the hockey puck mounts for a while with no problems. Cheap, simple and effective.
nice your dad a hotrodder ???
