DIY write ups complete. Check them out here.
I've completed some write ups on Nissan's S13 240sx 1989-1994. Check it out and let me know if you guys see any errors.
The list of completed write ups:
Nissan S13 240sx Axle shaft removal, dissassembly, rear hubs.
Nissan S13 240sx brake caliper removal and installation
Nissan S13 240sx drive belt routing for KA24E and KA24DE.
Nissan S13 240sx driveshaft.
Nissan S13 240sx brake pads.
Nissan S13 240sx brake rotors removal and installation.
Nissan S13 240sx brake system
Nissan S13 240sx clutch removal and installation.
Nissan S13 240sx Master cylinder
Nissan S13 240sx manual transmission overhaul
Nissan S13 240sx manual transmission removal and installation.
Nissan S13 240sx Power Brake Unit.
Nissan S13 240sx power door locks.
Nissan S13 240sx power mirrors.
Nissan S13 240sx serivce indicator and warning lights.
Nissan S13 240sx front suspension: strut assembly, hub and knuckle, ball joint, wheel bearing, tension rod, etc.
Nissan S13 240sx rear suspension: Wheel bearning adjustment, check ball joints, etc.
Nissan S13 240sx wheel alignment: Camber, caster, toe, etc.
Nissan S13 240sx heater system
Nissan S13 240sx valve clearance, ignition timing, TPS sensor, etc.
Nissan S13 240sx ignition system, distrubitor.
Nissan S13 240sx fuel pressure release, fuel pump, rails, injectors.
Nissan S13 240sx differential overhaul.
More updates coming soon...
Bump. The site has other repair info on differen't cars as well so check it out. www.garage411.com
Corrections and suggestions accepted as always.
Biggamehit
12-01-2009 07:22 PM
iroc07
08-29-2004 04:09 AM
