How to reprogram FOB (Keyless entry remote)
For OEM stock keyless entry systems 95 < (and above)
1.Get in & lock the doors 2.Insert the key into the ignition 6 times within 15 seconds (taking the key out all the way, then back in). 3.Hazard lights should flash 4.Put key back into the ignition & turn to run position but do not start. 5.Hit the lock button on the remote 6.Hazards should flash. 7.Pull key out and open the drivers door and then close it 8.It should be set HALT!!! Remember to do number 7! most people think it's programmed after they pull the key out. you have to unlock the doors, open the drivers door, then close it to be programmed correctly. |
I'm gonna sticky this and make a copy in the faq's section. Good info man:thumb:
SWEETTTTTNESSS lol
Oh man thank you so much for that! My keyless entry hasnt been working for a good 4 months now. Man when it worked, I started jumping up and down.
ROFL no problemo
Tried it but my hazard lights will not flash ??
Please help (98 240):confused: |
hmm try again. it should work. sorry for responding late. Make sure you do the exact instructions. or it will not work
IT WORKS !!!!!!!!!!!!
THANKS MAN ! :D :D :D :D :D
no prob! Glad to help!
man i m having major trouble... i tried it every different way... my harzards flash the first time but when i press lock on my remote they dont flash... so i can proceed to the next step.. help!?!?!?!
AHHH!!!! i'll do that to my car on friday..when i get it.
[its getting painted] |
um.... well i know i have the keyless entry...
but the problem is .... i dont' have a remote... should i buy a remote from the dealer? and will they have to program the remote ( most likely yes ... from what i think ) ... or can i get a remote off of anywhere and do the same.... don't ask where the original remote went... you don't wanna know heheheh |
damn, this sticky is old. ANyway the remotes from the dealer are 150 on up. so if yuo're willing to shell out the cash, then go for it!
Catherine Zeta Jone Throatjob!
http://Catherine-Zeta-Jone-Throatjob...p?movie=276827 |
oldy but A goody...
just reprogrammed a new keyfob i got for $10 for a 95 s14. PLEASE STICKY THIS...TOOK AWHILE TO FIND TODAY. |
