-   How Tos / Installations (https://www.s-chassis.com/forums/how-tos-installations-48/)
-   -   Rear Toe Control Rod Install (https://www.s-chassis.com/forums/how-tos-installations-48/rear-toe-control-rod-install-36713/)
positron Jan 5, 2007 04:51 PM
16 Attachment(s)
I swapped out my stock rear toe control rods with some aftermarket rods today...here's the pics.
Tools needed:
Jack
Jackstands
Socket wrench
17mm/18mm sockets
Breaker bar
Torque wrench
3/4 wrench
Crescent wrench
First, I jacked the car the up and put the stands under it.
Attachment 24679
Next, I used a 18mm socket and a 3/4 wrench to remove the toe rod bolt from the spindle. You'll need a breaker bar to bust both ends of the rods loose by the way.
Attachment 24680
One end down...one to go!
Attachment 24681
Use a 17mm socket and the 3/4 wrench to remove the bolt from the other end of the toe rod.
Attachment 24682
When you take the nut off you'll see the eccentric washer. Mark it off so you know exactly where it needs to be when you place it back.
Attachment 24683
Eccentric washer...for the alignment shop.
Attachment 24684
Pull the eccentric bolt from the other side near the differential...
Attachment 24685
...and boom you're half way there!
Attachment 24686
This may not happen to anyone else but I ran into a problem. The outer toe rod bolt on one of the spindles was facing toward the strut so when I tried to remove it I couldn't because it was ****-blocked by the strut. I just used a 17mm socket to take off the lower strut bolt and then moved the strut to the side so I could remove the toe rod bolt.
Attachment 24687
Here's a pic of the stock toe rod and the aftermarket toe rod. I went with Megan Racing.
Attachment 24688
Use a cresent wrench to adjust the new toe rod to the same specs as the stock one.
Attachment 24689
Next, you insert the toe rod then place the eccentric bolts and nuts back remembering to use the mark-off points you placed earlier to make everything line back up.
Use the 17mm socket and 3/4 wrench to cinch everything back on the inner part of the rod...
Attachment 24690
...and also on the outer part of the rod.
Attachment 24691
Now you'll need the crescent wrench to tighten the adjusting nuts on the toe rod down.
Attachment 24692
Attachment 24693
Attachment 24694
Torque the bolts down to 57-72 ft. lbs. and you're done. Time for an alignment. If you had to remove the strut like I did then you'll need to put the lower strut bolt back and torque it to 72-87ft. lbs.
jspaeth Jan 5, 2007 05:20 PM
Good write-up
I have some comments...I am doing this soon, it is basically the same as installing RUCAs
Anyone that answers this gets "bonus points":
When you install adjustable aftermarket toe rods or RUCAs, you still use the eccentric bolt/nut...I am worried that even once you get the car aligned properly, although the aftermarket linkage is now fixed in its length, what is to stop the car from getting out of alignment again due to the eccentric bolt rotating.
I am wondering if anyone has any good ideas for this? I mean obviously, you can make the eccentric nut REALLY tight to try to lock that end down, but the thought of it moving still pisses me off.....I wish there was some way to ensure that the eccentric bolt/nut stay in place....(and welding isn't an option bc then that piece is not coming off!)
positron Jan 7, 2007 10:13 AM
That's a good question. If everything gets torqued down to spec then it shouldn't rotate though should it? Unless you just curb check the hell out of your rear-end.:dunno:
JDMxDrift Jan 12, 2007 12:16 PM
Well the reason that eccentric washer is there is to provide adjustability for alignment shops. Since the new toe rods and RUCA's have more adjustability than that eccentric washer i don't see why you can't just use a regular washer now.
positron Jan 21, 2007 04:03 AM
I hope so because I wasn't able to use the eccentric washer and bolt because of the lower control arm bar.
jspaeth Jan 21, 2007 08:58 AM
You CANNOT use a regular washer....
The slot that you put the bolt through is like an oval, this provides room for the bolt to slide closer or farther from the wheel via the eccentric bolt....
If you just put a regular washer on, there is nothing really preventing that bolt from sliding within that slot....
Granted, if you tighten the nut alot, its got alot of force on it, but I would stick with the eccentric
positron Jan 21, 2007 09:30 AM
I've been constantly thinking about that since I put those back on and I think I'm just gonna take that bar off and put my eccentric washers and bolts back in. Better safe than sorry. You see the problem is those extra long bolts that they provide with the lower control arm bar don't have the the oval shape or the grooves for the eccentric washer to fit on with.
Bryan Jan 21, 2007 09:55 AM
nice write up
Babyrightside Feb 13, 2007 05:49 PM
Okay wtf is with all these random posts about porn.
If there real members then they must of gotten hacked if not then there robots.
Its really f u c k ing annoying.
positron Feb 14, 2007 12:01 AM
I agree! I look but I agree LOL!
Levi SPL S14 Feb 14, 2007 05:45 PM
^ at least your honest.
