Rear Traction Control Link Install
8 Attachment(s)
I swapped out my stock rear traction control links with some aftermarket links today...here's the pics.
Tools needed: Jack Jackstands Socket wrench 18mm sockets 3/4 wrench Breaker bar Torque wrench Crescent wrench First, jack the car up and place the jackstands underneath. Attachment 24671 Stock traction control link...it ends today! Attachment 24672 You'll need a breaker bar to break each end of the control link. Then use a 18mm socket and a 3/4 wrench to remove the traction link bolts. Attachment 24673 Next, I used a small hammer to tap out the bolts from the frame and spindle. Attachment 24674 Ran into a problem here, one of the traction link bolts was facing the rear upper control arm so when I tried to remove the bolt it was blocked. I used the same 18mm socket and the 3/4 wrench to remove the outer RUCA(rear upper control arm) bolt so I could take out the traction link bolt. Attachment 24675 Everything's pulled and ready for the new links! Attachment 24676 Use a crescent wrench to spec the link to the same size as the stock link. I went with the Megan Racing Traction Control Link. Attachment 24677 Now you can place the links and tap the bolts back in. https://i130.photobucket.com/albums/...2/IMG_1149.jpg If you had to remove the RUCA then you need to put it back the way it was as well. Attachment 24678 Don't forget to tighten the adjusting bolts with a crescent wrench. Torque the inner bolt to 51-65ft. lbs. and the outer bolt to 57-72ft. lbs. then hit up the alignment shop. |
nice, i just did my tension rods and about ready to do the whole rear end too. you didn't do RUCA's?
That's next on my list.
Nice write up
