How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
How to replace AC Condenser?
Old 01-03-2010, 12:26 PM
vbgambini's Avatar
Ive tried to search. Is there any write up on how to replace the AC Condenser on a S14? (Specifically 1998 240sx) I cant seem to find it anywhere. Thanks.
vbgambini is offline
Old 01-03-2010, 02:53 PM
there's really not much to it other than disconnecting the high pressure line from the compressor and the line to the pressure switch. you'll have to remove the fan shroud and mechanical fan so you can pull the radiator back and have access to it though.
i know that's not a very detailed explanation, but there's not much to it. it you have a specific question i may be able to clarify.
jramosthe1st! is offline
Old 01-03-2010, 03:21 PM
if you dont know how to do this you shouldnt be working on your own car....
battosaii930 is offline
Old 01-03-2010, 08:47 PM
vbgambini's Avatar
By the way, I do everything on my car that I can handle and understand, I just dont have any experience with Air Conditioning systems. I didnt think there was much to it, but i heard there can be complications while doing it with the freon, pressure and such.
Old 01-03-2010, 08:48 PM
just make sure you discharge the system.
Biggamehit is offline
Old 01-03-2010, 08:55 PM
vbgambini's Avatar
How do I do that? the problem is that the condenser has a huge gash in it and i believe it leaked and probably dried out now.
Old 01-03-2010, 10:00 PM
if there's a gash in your condenser then there's no need to worry about discharging the system, that's already been take care of.
Old 01-04-2010, 08:26 AM
vbgambini's Avatar
ok. so it'll be ok to replace it myself then take it to be charged?
Old 01-04-2010, 09:42 AM
yes, it would also be a good idea to replace all the o rings to be sure that there aren't any leaks present. i'm not sure how many there are but there are quite a few.
Old 01-04-2010, 03:17 PM
yea it is really straight forward bro. download the FSM in the how to section to guide you with instructions.
vbgambini
06-01-2010 07:18 PM
kang128
08-25-2006 11:14 AM
raccoon601
10-25-2005 07:08 PM
l2aine
12-27-2003 04:55 PM
SlydeSHO
09-03-2003 11:17 PM
Quick Reply: How to replace AC Condenser?
