-   How Tos / Installations (https://www.s-chassis.com/forums/how-tos-installations-48/)
-   -   S13 300ZX Rear Brake Install (https://www.s-chassis.com/forums/how-tos-installations-48/s13-300zx-rear-brake-install-41156/)
positron Sep 9, 2007 01:06 AM
51 Attachment(s)
I did the Z32 rear brake upgrade today. I read this page http://importnut.net/300zxbrakeswap.htm and was compelled to attempt this upgrade. Props to Al because it can be done and quite easily.
Tools needed:
Jack
Jackstands
Socket wrench
Socket kit
36mm socket
27mm socket
22mm socket
19mm socket
17mm socket
10mm socket
Wrenches/10mm line wrench(for the brake hardlines)
Hammer
Screwdrivers
Needle nose pliers
Brake fluid
Drain pan
Attachment 20555
Z32 rear calipers.
Attachment 20556
240SX to Z32 stainless steel rear conversion brake lines from ProjectNissan.
Attachment 20557
Z32 ebrake extension kit from SuperautoBacs.
Attachment 20558
Z32 spindles and hub assembly...
Attachment 20559
I'm staying four lug so I only really needed the dust shield/ebrake assemblies and not the 5lug hubs or the aluminum spindles.
Attachment 20560
Z32 Brembro rotors redrilled to 4lug from Heavythrottle.
To do this brake upgrade and stay 4lug you'll need to remove the spindles, rotors, calipers and brake lines both normal and ebrake, that is if you want to keep your ebrake.
Attachment 20561
First you jack the car up and place jackstands in the appropriate places.
Attachment 20562
You'll need the ebrake engaged in order to bust the axle nuts loose so that's where you should start. Don't be like me, disconnect an ebrake line first not realizing that the wheels will spin without them and waste valuable time putting them back on....estupido!!! Remove the axle cotter pin and adjustment cap.
Attachment 20563
Use a breaker bar and the massive 36mm socket to bust the axle nut loose. You'll hear a loud screeching when it busts. Now that the axle nuts are loose you need to get to the spindles.
Attachment 20564
Remove the top and bottom caliper bolts with a 17mm socket.
Attachment 20565
You may have to wriggle it a little but the caliper comes off the rotor.
Attachment 20566
You need to use something to suspend it and keep it out of your way.
Attachment 20567
Go ahead and remove the axle nut that you bust earlier.
Attachment 20568
The rear rotors are slip fit so just pull them off unless yours are rusted to the hub.
Attachment 20569
Remove the axle spacer.
Your're almost to the spindles, now you need to disconnect the rear suspension arms from the spindle next.
Attachment 20570
The traction link(18mm socket/ 3/4 wrench).
Attachment 20571
The rear upper control arm(18mm socket/ 3/4 wrench).
Attachment 20572
The toe rod(18mm socket/ 3/4 wrench)....
Attachment 20573
...and the strut to spindle nut(17mm socket).
Attachment 20574
You may need a pry bar to persuade some of the arms off of the spindle.
Attachment 20575
All arms removed.
Attachment 20576
Use a rubber mallet to knock the axles out of the spindle. I only had to use the mallet on the passenger side, I pushed the axle out with my fingers on the drivers side.
Attachment 20577
If it doesn't want to budge then use something to hold against the tip of the axle so you can "hammer and chisel" it out.
Attachment 20578
Axle out.
Attachment 20579
Push the axle to the side and you have access to the rear lower control arm nut.
Attachment 20580
Use a pair of needle nose pliers to remove the cotter pin.
Attachment 20581
If you're a poor man like me and don't have access to a impact gun then you need bust the hub bolts loose while the spindle is still attached to the RLCA...you'll need the leverage to do so. There are four hub bolts that need to come off with a 19mm socket.
Attachment 20582
Use a 22mm socket to bust the RLCA ball joint nut loose.
Attachment 20583
Use a ball joint tool to pop the ball joint loose from the spindle.
Attachment 20584
Insert the tool between the spindle and the ball joint and use a hammer to hit the end of the tool to pop it out.
Attachment 20585
My next project needs to be a new set of RLCA's because these ball joints are shot...pudding anyone?
Attachment 20586
Now that you have the spindle off you can remove the hub bolts.
Attachment 20587
Ran into a little problem here, when you take the hub bolts out the one part separates into three parts, the spindle, the hub and the dust shield. My drivers side spindle was seized apparently by the heat that was generated over a period of time and it would not come apart. I took it to a friend at a dealership and he pressed the hub out of the spindle for me. The passenger side spindle fell apart the second I removed the last bolt.
Attachment 20588
Here's the comparison between the 240SX spindle(top) and the Z32 spindle(bottom). The 240SX spindle is iron where the Z32 is aluminum. I would have liked to use the Z32 which is 7lbs. lighter but I would have had to get coilovers or Z32 shocks/struts because as you can see the only thing different is where the strut to spindle mounts are. They are completely different.
Attachment 20589
While I had my spindles off, I gave them a fresh coat of black.
Attachment 20590
The Z32 ebrake assemblies bolt up to the 240SX spindles by way of the hub bolts and this hole above the hub bolt holes on the spindle. These holes were crusted so I had to dremel them out.
Attachment 20591
Take three parts, hub, spindle and dust shield assembly and assemble them. Make sure you have the hub bolt holes aligned properly so you can reinsert the bolts properly.
Attachment 20592
Even after dremmeling out the hole for the dust shield, the mount that goes into the hole did not want to go so I took a note from a friend and used a old socket as a press and hammered down the spindle onto the mounting point. Once you get it started you may want to insert the hub bolts to keep it lined up. Once you get the spindle completely knocked down, use a 27mm socket for the nut that secures the ebrake assembly to the spindle.
Attachment 20593
Attachment 20594
Torque the hub bolts to 57-72ft. lbs.
Attachment 20595
The spindles are complete and need to be put back on the car.
Attachment 20596
Lay the ebrake lines across the subframe.
Attachment 20597
Place the spindle back on the ball joint, torque the nut to 52-64ft. lbs and reinstall a new cotter pin.
Attachment 20598
Put the axle back into the spindle.
Attachment 20599
I decided to replace my old suspension arm bolts...
Attachment 20600
and strut to spindle spacers/bolts.
Attachment 20601
Reinstall your suspension arms. Torque the traction links, rear upper control arms and toe rods to 57-72ft. lbs.
Attachment 20602
Torque the strut to spindle nut to 72-87ft. lbs.
Attachment 20603
Put the axle spacer back then the axle nut.
Attachment 20604
You won't be able to tighten the axle nut until you secure the Z32 ebrake lines.
Attachment 20605
positron Sep 9, 2007 01:09 AM
37 Attachment(s)
Remove your center console and the ebrake boot and use a 10mm wrench to loosen the tension on the ebrake lines so that you can remove them.
Attachment 20493
The 240SX lines can be taken out by removing the screws from the mounts here in the driveshaft tunnel.
Attachment 20494
To remove the lines from the T-bracket, turn the lines to the side of the bracket where there is an opening and use a screwdriver to pop the cylinder out by pressing from the bottom.
Attachment 20495
Done!
Attachment 20496
Use a 10mm wrench to remove the ebrake mounts from the subframe.
Attachment 20497
You can pull the 240SX ebrake out and done!
Attachment 20498
When you install the Z32 ebrake cables there are two stock mounting points on the rear subframe that you can use to bolt them to if you wish.
Attachment 20499
If the lines that you have need to be extended in order to reach the T-bracket then take the ebrake extension kit...
Attachment 20500
and connect the lines.
Attachment 20501
Run the lines across or thru the subframe.
Attachment 20502
Insert them both into the T-bracket.
Attachment 20503
You'll need to secure the cables onto the floorboard in order to get them to function correctly.
Attachment 20504
These brackets came with the ebrake extension kit for mounting the cables but I used these to mount the cables to the subframe...
Attachment 20505
You can see them if you look closely.
Attachment 20506
I used some metal brackets that I got from Lowes to secure the ends of the ebrake cables to the floorboard. I bent them into a L formation, bolted the lines on and was able to bolt the brackets to the same stock location that the 240SX lines were bolted to.
Now that your ebrake functions, you can install the rotors, calipers and torque down the axle bolts.
Attachment 20507
Z32 vs. 240SX rotors.
Attachment 20508
You won't be able to remove the 240SX calipers until you take the 240SX regular brake lines off the car.
Attachment 20509
Place the Z32 rotor on the hub.
Attachment 20510
Decided to replace my old caliper bolts with new bolts also.
Attachment 20511
Apply brake quiet to your pads and insert the pad with the mounting tab into the caliper before you bolt the caliper to the spindle. I tried but you can't install the pad with the tab on it unless the caliper is off the car.
Attachment 20512
Use a 17mm socket to reinstall the caliper bolts and torque to 28-38ft. lbs.
Attachment 20513
Now you can insert the other pad from the top of the caliper.
Attachment 20514
Pad retainer.
Attachment 20515
Bolts.
Attachment 20516
Spring retainer.
Attachment 20517
Done with the caliper install.
Now on to the brake lines.
Attachment 20518
After removing the brake hose clip, use a 10mm wrench(preferably a line wrench) to remove the brake hose hard line fittings...
Attachment 20519
and replace with the stainless steel line...
Attachment 20520
and clip it down. The stainless steel line uses a 19mm wrench. Keep the 10mm wrench on the hardline to hold it steady while you turn the fitting on the new line. The hardlines anywhere on a car can be a pain to get off without rounding them off so I hit it with PB Blaster and after letting it sit, I would turn and wipe in order to get the PB risidue off the hardline to keep it from getting in with the brake fluid.
Attachment 20521
During this procedure I busted one of my brake hardlines from the chassis to the brake hose so I removed it, went to Autozone and had another hardline cut and bent to replace it with. You'll need to bleed the brakes later.
Attachment 20522
Reinstall the adjuster cap and the cotter pin to the axle after you torque the axle nut to 151-201ft. lbs.
Attachment 20523
Z32 rear setup...
Attachment 20524
Finished!
As far as using wheels goes, I found out that the stock S13 alloy wheels could possibly be used with the brake upgrade. Apparently there were three types of Z32 calipers, 26mm aluminum, 30mm aluminum and 30mm iron.
Attachment 20525
There were also two types of S13 stock alloy wheels that looked the same but were different on the backside....
Attachment 20526
This type with the grooves in them...
Attachment 20527
and this type without the grooves. You can use the 26mm aluminum calipers with the stock alloys without the grooves in them.
Attachment 20528
I was able to mount these wheels on the car with the 26mm calipers and spin the wheel without any contact between the caliper and wheel...
Attachment 20529
but there was absolutely very little space in between the two...but it is possible.
battosaii930 Sep 9, 2007 01:45 AM
lol damn dosnt look to hard only reason i sold my rear z32 calipers is cause i thought it was hard to do hmm i might have to buy myself another set
RuizXIII Sep 9, 2007 01:10 PM
Good write-up man.
I can see we are very alike, buying little things like new bolts and what not so everything is 'fresh' and not half-assed style
No Hammer of Thor pix? :(
Good Write-Up dude. I will be using this for reference in the near future.
Biggamehit Sep 9, 2007 01:25 PM
looks very good bro..
splay Sep 12, 2007 03:50 PM
ok so if i go crossovers i can use the spindals too? will that work on a hicas system? what about the front spindals will they work also?
very nice writeup btw :)
positron Sep 14, 2007 10:11 AM
From what I've researched, you can use the Z32 coilovers and struts/shocks but there is a small stock spacer that you will need to close a gap for where the 240SX RLCA's bolt up.
positron Oct 3, 2007 02:39 PM
Update!!!
16 Attachment(s)
I messed up the adjustment nut on my ebrake handle when I first did this conversion so I've been riding around with barely an ebrake because I could not adjust it. I bought another handle from a forum guy, got it yesterday and installed it today. I also reinstalled my Z32 ebrake cables and this time I did so without the use of the ebrake extensions.
Tools needed:
10mm socket
12mm socket
Phillipshead screwdriver
Prybar
Attachment 20053
After removing the console, use a 10mm socket to remove the console bracket.
Attachment 20054
Take the console bracket off and use a 10mm socket to get the ebrake line off.
Attachment 20055
Use a 12mm to remove two bolts holding the handle to the chassis, one on each side.
Attachment 20056
Disconnect the harness from the ebrake, this lights up the "BRAKE" on your gauge cluster.
Attachment 20057
Now you can slide the cable out from under the copper box and remove it.
Attachment 20058
Done!
Attachment 20059
Put the new handle in and reinstall.
Attachment 20060
Adjustment nut.
Attachment 20061
For the Z32 ebrake cables I removed the extensions and used a prybar... Attachment 20062
to remove the mounting brackets from the cables.
Attachment 20063
Now I can run the cables throught the stock location on the subframe, this opening here. You wouldn't be able to get them through the hole with the mounting brackets attached.
Attachment 20064
This stopper fits flush here.
Attachment 20065
The cable runs right to the t-bracket.
Attachment 20066
Now you can connect it.
Attachment 20067
Make sure you have the adjustment nut loose and the ebrake handle down for the slack, also so you can reach the t-bracket with the cables. I also suggest connecting the cable on the exhaust side first because of the limited space.
Attachment 20068
An added bonus, now you can reuse the mounting brackets that you pryed off, just put them back on the cables and you can mount them to the same stock mounting points that the 240SX cables were mounted to flush against the undercarriage of the car.
zoomswimmer Oct 14, 2007 09:53 PM
Where did you get all the bolts? I can't find some of them?
positron Oct 15, 2007 07:02 AM
Courtesy Nissan http://www.courtesyparts.com/betasit...1418_1419.html You can get any part you need for this car on that site...and they have pictures which is very nice. Just make sure you pay attention, I bought a set of pin bolts instead of caliper bolts because I wasn't looking at the right part and where it connects....DOH! Courtesy Nissan is cool, just sent them back and was refunded the money.
urmyhero4now Oct 15, 2007 04:24 PM
sticky
imnotmatt1189 Nov 11, 2007 11:40 AM
how much did this cost you?
positron Nov 13, 2007 12:44 PM
300ZX rear hubs=$399, sold the spindles for $80 and the 5lug hubs for $160. Could have gotten a better deal on just a set of dust shields if I had been more patient. I came across a set of dust shields for $100 like two weeks later.:angry:
The rear calipers powder coated with pads=$169
Brembro rotors=$150
Stainless steel lines=$40
New hardware(bolts, hose clips and washers)=$20
36mm axle nut=$17 and THIS is the part that I complain about WTF!!!:soapbox:
shrimpscampi Apr 20, 2008 02:26 PM
Thanks for posting this...it will be very helpful soonly...
terribleone Jul 26, 2008 09:15 PM
so hows longs it take to do the rear?? i "tried" it on my old 240 anddd didnt know what i was doing but ill have to do it on my new 240
