S13.4 Conversion headlights
3 Attachment(s)
Hey guys this how you wire up the headlights. The method I used is to go to a junk yard find a S 14 headlight harness. It make it easy to do.
1. The s13 headlight harness varies from year to year. 2. The s13 has 3 wires. Pink and black, green, and red and blue. 3. On s14 harness u have the red and blue and black for low beams 4. S14 has a red and green for the high beams but these also varies from year to year. 1. Take s14 harness low beams, (red & blue) wire into the s13 (green wire). 2. Take the s14 high beam(red & blue wire) harness and wire into s13 (red & green). 3. Take both ground wires from s14 which are (black), and wire into the s13 (pink & black) wire which are ground wires. (Note: these colors for the wiring varies from year to year. This is for a 91 s13.) If you have any questions fell free to ask! |
