S13 Wheel Stud Replacement
32 Attachment(s)
I finally got off my duff and replaced that wheel stud that I broke a couple of months ago.
Tools needed: Jack Jackstands Socket wrench 17mm socket 14mm socket 3lb. hammer Washers Lug wrench Attachment 23332 I've been riding around for a couple of months now with one missing lug nut on my rear drivers side...it ends today! Attachment 23333 First, jack the car up, place your jackstands in the appropriate places and remove the wheels. In order to gain access to the hub so that you can remove the broken wheel stud, you need to remove the brake caliper and the brake rotor. Attachment 23334 In order to get the rotors on and off you'll need to remove the brake caliper. You start by removing the torque member bolt with a 17mm socket. There are two bolts on the torque member, top and bottom. This is the top bolt. Attachment 23335 This is the bottom torque member bolt. Attachment 23336 Torque member bolt-top. Attachment 23337 If you can't wriggle the caliper off then you may need to slightly loosen the pin bolts. There are two pin bolts. This is the top pin bolt. Attachment 23338 This is the bottom pin bolt. Attachment 23339 Here's the caliper. Attachment 23340 Here's the torque member that it bolts to. Attachment 23341 You don't want the caliper hanging by the brake line, which could damage the line, so you use something to hold the caliper with while keeping stress off the brake line. I didn't have any metal coat hangers so I used a small bungee cord. Put one end on the top of your springs and hang the other on the caliper. Attachment 23342 Rotor Attachment 23343 The rear rotor is slip-fit so it just comes off when you pull it. Attachment 23344 Exposed hub. Attachment 23345 You'll probably find that the wheel stud is rusted so hit it with some PB Blaster and let it sit for 10 minutes. Attachment 23346 After the PB does it's thing, you're ready to knock out the wheel stud. Attachment 23347 Grab your trusty hammer like the Mighty Thor and raise it toward the heavens...uh, the Mighty Thor isn't black and he doesn't wear a wrist watch either. Attachment 23348 Here's the stud that needs to be swapped out and the new stud...shiny!!! Attachment 23349 To remove the stud, you need to knock it out with a hammer, I used a 3lb. hammer. I started off by hitting it from my left, I hit the stud probably 20 times and it didn't budge. Attachment 23350 I got a little angry that it wouldn't move so I switched to my right side and manned-up. The first blow that I hit it with knocked it loose. Attachment 23351 After knocking it loose, I used a small hammer and a flathead screwdriver to hammer and chisel the stud the rest of the way out of the hub. Attachment 23352 Finally got it out! Attachment 23353 The busted stud and the new one...again. Attachment 23354 Take the new stud... Attachment 23355 and insert it into the hub. Put some anti-seize on it before inserting to keep it from rusting in the future. Attachment 23356 This is where the washers come into use. You'll need to place a couple of them on the wheel stud to keep the lug nut that you're going to use from bottoming out. Attachment 23357 Take a lug nut and place it on the new stud. Attachment 23358 Lug wrench. Attachment 23359 Tighten the lug nut as far as you can, doing this will pull the new wheel stud into the hub. Attachment 23360 You'll only be able to turn the lug wrench so far because of something you did earlier. By taking off the caliper and disconnecting the e-brake, the wheel now spins freely making it a pain to hold still and turn the lug wrench. Attachment 23361 This is when you need to put your brake rotor and caliper back on so that you can use the e-brake to keep the wheel immobile. After you get everything back together, place a spacer or two on the wheel stud again. Attachment 23362 Now that the wheel doesn't move you can tighten that wheel stud as far as you can get it in order to seat it into the hub. Attachment 23363 Finished! Put your wheels back on, drop the car and you're ready to go. |
Lawlz @ the Hammer in the Heavens part!!!
Good Work Tron |
you mean thor i think you would have been better off removing the hub. you reduce the likelihood of damaging the hub bearing. |
