Throttle Body Spring Assembly
13 Attachment(s)
So you've taken it apart and can't remember how to reassemble it, well here's your guide.
Here is the order of installation from left to right. Attachment 9086 Just to get this out of the way, I'm going to say "slide down the shaft".... alot So grab piece 1, slide it down the shaft with the flat side towards to back of the tb when shaft is in the closed position. Attachment 9087 Piece 2 and 7 are similar, but 2 has a larger area cut out where 7 just has a slot on it. So with piece 2, slide it down the shaft with the cut out area towards the back of the throttle body. Attachment 9088 Then, take piece 3 and slide it down the shaft Attachment 9089 There are two parts for piece four, first slide the cylinder on, then the spring over that and position the spring as shown in the picture below Attachment 9090 Now, I just realized I forgot to take a picture for pieces 5 and 6. Piece 5 slide over everything and position it has low as it will go, with the collar facing away from the body assembly. Piece 6 is the cap for the top of the spring. You can see how piece 5 is position in the next picture. Piece 7 is where you are going to start to load the springs. As shown in the picture below, you want to first position the spring into the slot on piece 7 Attachment 9091 Once you have the spring in the slot, you need to turn piece 6 counter clockwise till you can slide it down the shaft. This will give you resistance since you are loading the spring. If you do this correctly your throttle body should have resistance when you open the throttle plate and the spring should close it. Attachment 9092 Next grab piece 8, the larger spring... slide it down the shaft, and then position piece 9 over it like this Attachment 9093 Piece 10 is a locking washer, position it as shown in the pic below. Attachment 9094 Then push down on the washer and you should be able to rotate in a way to lock everything together Attachment 9095 Now this is the hardest step of all, you have to get tension on the larger outter spring by moving this Attachment 9096 You need to move that tab back so it sits on the pulley with resistance. I found it easiest to use a piece of string to pull it back to where it needs to be and hook it on the pulley. Sorry for not having a pic showing how to do this step. Below is what you will have when you are done Attachment 9097 Once its on and snaps close with some force, you can finish with the washer and locked nut. Here's what mine looks like with the hi-throttle pulley Attachment 9098 |
good looking out, this could come in handy!
This just made my day. Thank you!
