afc neo help
ok i have got just about everything done on the new ka-t. Im having a problem with my afc neo. I wired it up just like the instructions said and nothing happened. Well when i connected the wires to a permanent ground through jump wires it came on. It will not stay on when i crank the car though. The lights just flash. What is the problem? I have searched and not found anything remotely related to this problem. As said before this is the last step to getting my new ka-t on the road. Thanks
what pin on the ecu is your power run to......... you issues is the power.
run the ground and power to a standalone source.. not the ecu and see how that works out |
