248 248 cam swap question
do anyone have a pic on how the 248 cam swap is suppose to look like so i can make sure im golden??i use the 4 teeth method and was wondering if there is a better option??..the idle is a lil ruff for me,i gotta hit the gas a couple of times to get her started...
000 yea ...would you guys recomend using a fpr with walboro pumps or a afc should be fine??using stock injectors for now with 89 pistons
my b 90 pistons the flat tops
What motor do you have?? And it would help if you would write in english, not gibberish. HAHA. Cant understand what your trying to ask.
lol my b..i was kinda of fallin asleep when i started this thread..i have the kade..
the 4 tooth method is the one i had always read about, were you set to TDC when you did the install? and does changing the idle speed do anything for the rough idle?
also, don't suppose you got before and after dyno numbers for this? |
i set the tdc to stock location and did the 4 tooth method..the 1st set of lobes has to face away from each other right???
do anyone has a pic of the cams so i can see if i did it right..do u do it by 4 chain links or 4 holes for the teeth
Originally Posted by 240smoke
(Post 383193)
Obviously, it is a KA engine that he is talking aboujt by the lift/duration cam that he is using 248/248. Anymore HAHA's and post whoring out of you; you and I will start to have some serious problems. Your comments on this forum are the only gibberish I see. |
The four tooth method is great for bottom end torque, but you will never have a smooth idle. The engine doesn't create a steady vacuum to keep itself running right. i never adjusted the idle speed when I had mine, but I doubt it will help. Running the three tooth method gives a perfect idle with a better top end boost.
yea...u wouldnt have a pic of what the 3 tooth looks like??the idle is a lil ruff
has any one tried the 240x240 cam swap??how do u set up the 240 cam on the exhaust side?vinny i know u know
The intake cam on the exhaust side would be rotated the same amount of teeth, in the opposite direction
oo ight i tried the 240x2 and 248x2..dont really care for how the idle feels.its totally crappy..i jus went back to stock till i get some bc's
