Adjustable Cam Sprockets - DIY
I've been lurking here for a while and through some of you might dig this...
Jim Wolf Technologies makes Adjustable Cam Sprockets for the KA24DE... They cost about $140... which puts too much of a dent into my beer fund... Now if you are a frugal type of car tweaker, like myself, you get more enjoyment out of you automotive hobby by "rolling your own" performance stuff... Why? Because you can. I was eyeballing the Good ol' JWT cam sprockets and the Install Instruction Sheet that goes with them... Including the stock key-hole on the cam gear, ol' JWT adds 8 more holes to allow adjusting of the cam timing... These holes allow advancement of the cam in 2.5 degree increments (+2.5*, +5.0*, +7.5*, +10*), or retarding the (-2.5*, -5.0*, -7.5*, -10*), all in relation to the stock setting. Lets see... 9 holes total... 360* / 9 = 40 That is a hole every 40 degrees.. I have a spare set of Cam Sprockets, access to a vertical mill with an indexing table on it... and very few morals So I take the spare sprocket: http://riley-music.com/BowsStuff/240...zed/1Stock.JPG and center it up on the indexing table with the stock key way set at the 0* mark on the index. I then spin the table 40* and mill a 0.25" hole through the sprocket. I keep doing this until I get all the way around the sprocket. http://riley-music.com/BowsStuff/240...sized/2BME.JPG Bingo.. adjustable cam sprocket....: http://riley-music.com/BowsStuff/240.../3Compared.JPG Checked and approved by the BME Quality Assurance Department: http://riley-music.com/BowsStuff/240...ed/CoolCat.JPG That should allow me to tweak my 248/248 cam setup in work at a more usable RPM range on my Project motor... :D |
hahaha thats funny as hell
yea i have been through this setup.. good one JWT makes a kit however.. thats where the guy got most of his info.. |
Yeah.. I'd rather try to make a set than give JWT any money...
Which is why I bought my JWT ECU used and decoded their encrypted ECU program... which actually isn't all that... Besides, I'd rather build stuff myself.. :) |
yea well thats all i have been doing sense i had my car.... more power to you.. and you learn a ton.
| All times are GMT -7. The time now is 03:31 AM. |
