Big problem, no start..
like you put the key in, accessories go on but once you try to start it, they all turn off and it doesn't even click.
have the battery tested but not just the volts, it could be that you don't have enough amps. there are other possibilities but this is where i'd start looking.
i bet its that crappy PA air, it probablly clogged up your intake
jk but seriously, get that battery checked out. |
check fuses...
edit: could his blown transmission have anything to do with this? I'm not mechanic, don't hurt me if it sounds stupid. |
I think its the transmission.
try this: key on the ON position. Shift transmission all the way to 2nd, then back to park THEN try to start it. if no go, try: key on the ON position. Shift transmission to neutral. try to start it. try combination of those above. This has helped me before. |
Originally Posted by shaban
(Post 379835)
check fuses...
edit: could his blown transmission have anything to do with this? I'm not mechanic, don't hurt me if it sounds stupid. its fine. its just this problem but still doing five speed swap. and like im pretty sure its the battery, i called my dad and told him to look it up and he was just like dude its your battery. ahhah |
Originally Posted by FuriousZ
(Post 379836)
(Post 379835)
(Post 379845)
yes it is possible for a faulty neutral safety switch or bent linkage to prevent the car from starting. based of the brief discretion i don't believe that to be the case here.
