car not starting
hey guys...
i own a 90 240 with stock KA iv simply put the ****in thing wont start... ive i replaced the fuel pump,strainer, and fuel filter...has plenty of freash oil...plenty of spark...just changed the coil too... wut the hell could it be, the parts replaced are pumping plenty of gas, the pump is priming fuel, guys i need help this thing is my means of transportation, any one isn socal willing to come down for a beer and help me out, please **tear** |
Originally Posted by DALAZ_68
(Post 325111)
...ive i replaced the fuel pump,strainer, and fuel filter...has plenty of freash oil...plenty of spark...just changed the coil too...
if the engine is turning when you turn the key, that eliminates the battery and the starter, next up is the coil, but you said you replaced it, next, check to see if power is going to the coil, to the distributor and to the plug wires. you've basically eliminated the fuel part of the problem, so i'm guessing it's electrical. hope this helps |
or out of time.
turn out to be a blow hose at the fuel pump... but it runs now
I have the same car. Wasn't starting. The problem?
http://personal.stevens.edu/~wraymond/cam/dave.jpg Camshaft snapped. |
DAMNNN!!!!.....welll mine wasnt that bad thank goodness
