Car will not start...
Well, I go to start my car about a week ago and it wont start. Battery is good, I'm getting fuel, Getting spark, throttle body is opening, ignition relays look ok. I don't know what else to look at....the cars turns over and wants to start, but wont. Anyone have any advice??? Thanks in advance.
timing?
your timing is out.
Check the distributor position, retime as needed
have you changed your spark plug wires recently??? if you did it's possible you got the firing order out of wack. for instance my firing order is 180 degrees out of wack. took me nearly 4 hours to realize that. just goes to show you that the book doesn't cover real life problems.
thanks for the input guys, tomarro after work i'll check the timing...
