drain plug god damnit!!!!!
so my radaitor drain plug is all messed up a screw driver wouldn' turn it so i tried drilling it out and the stupid thing still wouldn't come out. any ideas?
make sure your turning it the right way or just drain the coolant by disconecting your lower rad hose but be careful cause it'l be messy
Originally posted by franman s13 make sure your turning it the right way or just drain the coolant by disconecting your lower rad hose but be careful cause it'l be messy |
Drilling? I would most definately flush your system to make sure that you don't have any crap floating around in your antifreeze.
Originally posted by twofotisx Drilling? I would most definately flush your system to make sure that you don't have any crap floating around in your antifreeze. |
how do you bleed the system!!!
when i have my bleed screw open only steam comes out and the radiator only shoots up coolant |
Originally posted by kang128 how do you bleed the system!!! when i have my bleed screw open only steam comes out and the radiator only shoots up coolant BTW: the bleed screw and the radiator cap are two seperate things. If all you see is steam coming out of the actual bleed screw (on the intake manifold) then that's some mean air pockets you've got in there (= bad) LOL I picture like a steam train. Hah. |
i did follow dr's instructions. and the steam did come out
so should i just wait till the steam dies out?? you bad by its bad but fixable?!?!?!?... |
bad because your enigne has a proclivity to overheat. This is after you've drained and flushed your system or during the process? I know that the first time that I did a complete flush and refill on my coolant I forgot to open the bleeder valve when I ran it for a few minutes and the engine temp start to go up high. So I whacked myself over the head with the Chiltons guide, realized I was a moron, ran the car with the bleeder valve open for about 5 min, and then all was done and accounted for.
| All times are GMT -7. The time now is 03:31 AM. |
