E6 cam cap bolt
Yeah, my bolt broke off in the head, then the EZ out reverse bit broke in there. How's about I don't run one of the bolts, specifically the inner E6 bolt
opinions, tips, hints, advice, konami code |
I dont really have any advice. But i am pretty sure i have a s13ka head that i will give you for free. its just a bare head, so you would have to get everything swapped over to it. If you intrested, just let me know. you'll just have to pay shipping. btw i live in south carolina. I got an sr now and ive been trying to get rid of this head. lol, if you dont want it, its going to the scrap yard.
i had a friend do that and he ended up spinning a rod bearing. lmao
probably just a coincidence, i don't see it hurting but i def wouldn't just forget about it and eventually try to fix it. in other words don't let this stop progress. |
Originally Posted by 1993Coupe
(Post 355356)
probably just a coincidence, i don't see it hurting but i def wouldn't just forget about it and eventually try to fix it. in other words don't let this stop progress. http://www.sears.com/shc/s/p_10153_1...d=bolt+remover if there isn't a stub for you to get a hold of you'll probably need to have a shop see what they can do. |
if the bolt isnt too deep, you can try to weld on a little bubble to the top of the stud and then grab it with some vice grips and spin it out.
careful you only weld on the bolt. |
Contra Code: ↑ ↑ ↓ ↓ ← → ← → B A
