Ecu code 82 which sensor?
Old Jun 19, 2007 | 03:58 PM
MasterOSkillio's Avatar
I have a 95 240sx OBDII
I just wanted to make sure really quick that ecu code 82 is the code that corresponds to the crank angle sensor that is located on the top of the transmission, right behind the engine. This is the sensor that detects the flywheel rotation with the magnet correct?
If I am wrong and it is another sensor please let me know which one, and where it it located. Thanks for the help.
Old Jun 19, 2007 | 05:57 PM
BigVinnie's Avatar
Yep 82 is the crank shaft position sensor.
Old Jun 19, 2007 | 06:07 PM
Damn, I replaced the sensor, and the ecu keeps giving me that code......what the hell is going on?
Old Jun 19, 2007 | 06:11 PM
BigVinnie's Avatar
Did you reset the ecu like you are suppose to after installing the sensor...
You need to erase all trouble codes.
Old Jun 19, 2007 | 06:15 PM
Yeah I reset the ECU so it blinks 55, but after running the car once, the second time I turn it on (the engine), the engine light comes back on, and it shows code 82.
Old Jun 19, 2007 | 06:36 PM
BigVinnie's Avatar
You should contact Brian. He goes by Orion. He would happen to know how to get by the code. e has an OBD2 KA that is heavily modified...
Here is his email.
orion@gru.net
Or you can reach him at www.ka24development.com
Old Jun 19, 2007 | 06:49 PM
Thanks I will send him an email
3dka24
Nov 25, 2006 10:46 PM
nismoman
Aug 22, 2006 01:12 PM
bcvjj21
Oct 30, 2005 12:00 PM
Tanshin
Feb 22, 2005 01:29 PM
nishioSX
Jan 26, 2004 10:02 PM
