Ecu code 82 which sensor?
I have a 95 240sx OBDII
I just wanted to make sure really quick that ecu code 82 is the code that corresponds to the crank angle sensor that is located on the top of the transmission, right behind the engine. This is the sensor that detects the flywheel rotation with the magnet correct? If I am wrong and it is another sensor please let me know which one, and where it it located. Thanks for the help. |
Yep 82 is the crank shaft position sensor.
Damn, I replaced the sensor, and the ecu keeps giving me that code......what the hell is going on?
Originally Posted by MasterOSkillio
(Post 321838)
You need to erase all trouble codes. |
Yeah I reset the ECU so it blinks 55, but after running the car once, the second time I turn it on (the engine), the engine light comes back on, and it shows code 82.
(Post 321840)
You should contact Brian. He goes by Orion. He would happen to know how to get by the code. e has an OBD2 KA that is heavily modified... Here is his email. orion@gru.net Or you can reach him at www.ka24development.com |
Thanks I will send him an email
| All times are GMT -7. The time now is 07:04 AM. |
