electric fan
Old Feb 2, 2005 | 11:09 PM
ca177or4's Avatar
electric fan
im gonna convert my belt driven fan to an electric fan so my motor wont strain as much anymore.....does anyone no wat size belt i need to use after the change over?
Old Feb 3, 2005 | 03:34 AM
wikd240's Avatar
why not remove the fan altogether and install a set of electrical fans??? unless you are meaning turning your water pump into electric drive like on race motors... but even then the fans are still removed so there is no additional drag on the electric waterpump motor... the belt would depend on the size of the electric motor pully being used... pitch and width of that pully will decide what size of belt you need for the conversion... i would think this would be easier...(taken from this board)
http://www.club240.com/forums/showth...=electric+fans
and the end results of this thread makes it easier and faster to get to the point
fan conversions...
http://www.fordmuscle.com/archives/2...an/index.shtml
Old Feb 3, 2005 | 10:07 AM
ca177or4's Avatar
dam wikd....u got the answer for everythin....LOL.
i'm gonna take out the fan and put an electric fan. but im still gonna have the water pump run wit the belt...wait...if i take jus the fan of...i wouldnt need to change the belt wood i?
Old Feb 3, 2005 | 11:59 AM
reelten's Avatar
No need to change belts unless you're replaceing the belt driven waterbump with an electric one, Just unbolt the fan/clutch remove it, put the nuts back on and tighten and you're done.
Old Feb 3, 2005 | 12:07 PM
drnovascotia's Avatar
Well answered everyone
Many people do this and get a fan or two. I myself had 2 10" Sentra fans, this 240sx i'm gonna get a 3.8L taurus fan.
Dr.
Old Feb 3, 2005 | 12:08 PM
reelten's Avatar
Here is some pictures of my setup
Hope those help you get an idea
Old Feb 3, 2005 | 12:29 PM
ca177or4's Avatar
nice...thats wat i wat i had in mind...thx guys...wat fans did u get reelten??? n did u hook it up to a switch or wat?
n did u guys feel a difference in this upgrade?
Old Feb 3, 2005 | 12:58 PM
reelten's Avatar
I have the Flex-a-lite Twin-Line electric fans, I hooked it up to the AC fan power (removed the ac fan for the twins) and shorted the relay to give power to the fans but not turn on the AC's clutch, So the switch inside the car for the AC turns on only the AC clutch
The Fans run full time and its better for the life of the engine and all its parts to run cooler, I also installed a nice 149 degree thermostat too, So now the heater blows warm air, never really gets hot
And yes the car seems to have a little bit more power, it just seems stronger when you step on it, like when the cars cold
Old Feb 3, 2005 | 01:06 PM
QR25DE's Avatar
was the wiring hard? cuz i suck at that =0(
Old Feb 3, 2005 | 01:18 PM
ca177or4's Avatar
so wait...ur ac is gone? cant i just hook it up to a switch to go insside the car and turn it on when i turn the car on?
Old Feb 3, 2005 | 01:19 PM
ca177or4's Avatar
my fault didnt occur to me that i posted twice...sorry
Old Feb 3, 2005 | 01:31 PM
reelten's Avatar
Found this after I figured it out on my own, its pretty much the same but I wired things differently.
240sx Electric Fan Howto
its pretty simple, you can probably just get power from some place else to.
Old Feb 3, 2005 | 01:39 PM
reelten's Avatar
I still have AC yes, When I hit the AC switch in the car the AC clutch is started and the air blows cold, Before the switch started the AC clutch and the electric fan, witch was also with the belt driven fan to help cool the added heat, now it only controls the clutch alone so i still have AC
You could put a switch in the car but then run the problem of forgetting to turn it off and drain the battery, but its your call,
You can, if you have better wiring skills then me, wire it into the ignition power so it can only run when the car is on and shuts off when you turn off the car.
Old Feb 3, 2005 | 01:47 PM
ca177or4's Avatar
thats wat i was thinkin of doin.or to somethin that has 12v when the car is on
Old Feb 3, 2005 | 01:48 PM
ca177or4's Avatar
oh yah...is that setup for the link the same as an s13?
