Electric Fan
Wusup guys? i was wondering where a good place to get a electric fan for a '93 240 would be. Any help is greatly appreciated. Thanks
Are you looking for a stock replacement for the electric a/c fan?
If you're looking for an aftermarket electric to replace your engine fan, check www.summitracing.com. They have a pretty good selection. -Justin |
well i was lookin at getting a perma-cool high performance 10" electric fan, so does any one have any comments or anything on this electric fan?
Do you have AC?
If so go with a twin fan unit. I would look for a unit where the fans are connected and mount to the radiator. Spend the money. I have found that these kits with the zip ties blow. |
I put twin dsm fans on my supra, the loss of the clutch fan was 10 hp. Take some measurements and find something in a junk yard for around 50 bucks. And zipties work fine, mine are still there with no problem, and it holds them very well, and the car feels like the same improvement when i put a lightweight crank pulley on it. You can mount a switch inside the car to turn her on.
Good luck:D Kam |
Originally posted by 7mgte in a 240? I put twin dsm fans on my supra, the loss of the clutch fan was 10 hp. Take some measurements and find something in a junk yard for around 50 bucks. And zipties work fine, mine are still there with no problem, and it holds them very well, and the car feels like the same improvement when i put a lightweight crank pulley on it. You can mount a switch inside the car to turn her on. Good luck:D Kam I am going to forgo poking holes in my new radiator and I am going to mount them properly. |
