A few Questions.
Okay well my truck is sold on saturday which means I get my car that day. Now I was tossing up a few ideas on some things to buy and the first would be cams. Now I can get the sage 1,2,3. Now my question for the cams is which would be best to run and what needs to be done to run it? I still want low end power but I also want top end power. I was told the 3 would basically destroy the low end power so I was kinda thinking the 2. Now will I have room and not be hitting a piston? Also Would it be pointless to get a High fuel rail,new injectors,new fuel pump? The high fuel rail is adjustable also.
Thanks! -it is the ka24DE |
so when you say cam i assume you're referring to the ka24e which has one cam and not two like the de. or are you talking about another engine altogether and not a ka?
IF it's a DE, PDM Stage 2 Cams make some pretty good power through the whole rpm band...
(Post 376210)
