Fuel Filter
Fuel Filter
Im getting ready to do a full tune up this weekend, and I have heard people talking about using the 300zx fuel filter. Has anyone done this? Any noticeable benefits? Is it worth it or should I just stick with the 240 filter?
i use a 300zx filter. it just provides more flow.....
i highly doubt there would be a HP increase.
but it is like twice the size of the stock unit..
will come in handy when you increase fuel preasure.
Yeah, but the Z's pump runs a higher pressure. Since the in and out holes on the filter are the same size as the 240's I don't see how it'd let more fuel into the engine. It may withstand higher pressure better.... but I haven't seen anywhere that says it does. Either way it'd be a waste with a stock fuel pump (if it costs more). So I'd just buy whatever's cheaper.
well i never compared the prices.
but bigger is usually better.........sort-of.
so that's what is in my fuel system
i bet i got like 5 or 6 more hp from that "mod"
The deal with the 300zx fuel filter is that it is larger, and provides a larger filtration surface, which makes it last longer than the smaller 240sx one. The flow isnt changed cause like what has been said, ur not changing nething in te fuel system, just the filter. People that say they have noticed a big change, it is more likely that u were due for a new filter and are noticing that change. The 300zx one is cheaper oddly so mine as well use it.
thats my take...
thats my take...
Limited Slippin
Mar 17, 2016 09:27 AM
BILLYhoang
Mar 17, 2008 08:51 AM
