fuel injector probs
My 92 KA is giving me crap with the #2 fuel injector. It is the 2nd one from the front. I replaced it, but my motor still shakes. But, when I push down on the wires real hard, it straightens out. I have no clue what to do at all? Replace the wire clip or the wires?
the plug for the injector maybe going bad. check the little O ring if its in place. if you have to push on it, then that means theres a bad connection...look for another connector and see if it works.
aarOn |
That is what I have been thinking. But where would I get a connector from?
another car
did you replace the o-ring? those are normally what cause the problem. Dr. |
Have you tried putting some dielectric grease on the connections?
Yes, I have put new o-rings on. No, I have not tried the grease.
Thanks Dr. and Jerome. I will try what was said.:thumb: |
