Fuel Injector removel and install
Im tring to change my fuel injectors on my 89 240sx with a ka24e in it. I got some cheesy insturctions from a print out of chilton's repair manual(because they wont let u check them out). Basically what i need to know because the insturctions were crap is where do i relieve the fuel system pressure at and what and where is the BPT valve?
Thanks for the help! |
you can relieve pressure by opening your gas tank cap.
You should also pull the fuel pump fuse while the car is idling and let it die.
ahh!@ you beat me to it!
While you're doing that, if you haven't in a while you should definately replace the fuel filter as well. Dr. |
