Getting gas getting fire turning over and wont start
Old Oct 16, 2007 | 08:00 PM
Whattup32526's Avatar
Ok heres the deal i have a ka24e Just got the car first few times I tried starting it I kinda had to flood it to get it going....once it cranks it runs fine...turn it off and it wont start again......acts like its not firing so i pull the plugs and stick them in the plug wires out of the engine...touch to something metal and i get a small spark more like a pulse while someones turning the key....tried number 2 plug same thing.....same thing in all of them....i have new plugs and wires....i know the coils firing cause from the coil to the distributor it sparks when touched to metal.....i know im getting gas cause when i pull the plugs they smell of gas...a lil....so whats the deal? any help?
Old Oct 16, 2007 | 09:02 PM
did this just happen on it's own or did you mess with the engine?
as of right now i'd say there's a problem with your distributer,distributer cap and or router. it could be as simple as a bad connection, warn router or as bad as dead distributer.
dkdeleon's Avatar
check your timing
Old Oct 16, 2007 | 09:59 PM
I second the timing.
Old Oct 16, 2007 | 10:16 PM
timing being off wouldn't give you a weak spark. i'm not saying that's not the problem though.
Old Oct 17, 2007 | 03:44 AM
dkdeleon's Avatar
???? I did not see where Whattup32526 stated having a weak spark.
Old Oct 17, 2007 | 06:10 AM
^me either, the spark he described seems normal to me.
Old Oct 17, 2007 | 07:22 AM
CharlesJ's Avatar
Club240 Staff
Check for air leaks, bad connections, leaky injectors. Also bad or old fuel
Old Oct 17, 2007 | 07:36 AM
right there.
or at least that's how i understood it so i could be wrong
Old Oct 17, 2007 | 08:16 PM
Ok so tonight i tried again........still nuthin...and everythings new...new plugs wires, rotor button, distributor cap, you know what a car sounds like when its not firing? its just turning and turning....now i loosened the distributor bolts and turned it a lil either way while turning the key....and it acts like it wants to start when i wiggle the distributor....and i hear a lil squeak...anyway to test the distributor?? Its really expensive to replace but if every thing else is brand new.....it could only be that right?? like i said before the other times i got the car to crank it would run fine.....then not start
Old Oct 17, 2007 | 08:20 PM
Oh and can someone post a close up of any and all wires attached to the distributor and where they go....(not plug wires) i know where they go
Old Oct 17, 2007 | 09:51 PM
the distributer only has one plug that is right in front of the engine. did you look to see if any injectors were leaking like charles suggested?
also you should check the resistance on your coil if you haven't already.
Old Oct 18, 2007 | 04:28 AM
none of the injectors are leaking, checked that...... how do i check the resistance on the coil.....now i was getting real nice spark from the coil....
Old Oct 20, 2007 | 07:22 PM
ughhh
maybe i should just sell the dang car. Its gunna cost too much to tow it to where im moving........wonder if i could get 1500
Old Oct 20, 2007 | 08:48 PM
txsileighty's Avatar
gotta be timing, i have the ka24de, it would turn, barely run if i held the gas down then shut off....
i had to go on gear tooth at a time....put it at tdc, and make sure rotor was pointing to #1 cylinder and put everything back, try starting it...and if it didn't work did it all over again until i found the right position....it was time consuming...
but i say timing...don't give up too easily...
