Headlight Control Unit
1 Attachment(s)
any one who know how to install Headlight Control Unit for a 89 nissan 240sx that Give the vehicle the Lazy Eye Look. PLease help if you know any one who do.
Thank. |
do you have the pivot unit?:dunno:
yes, I have the pivot unit. I need help on where are all the wire going to. I know that RED is for ground and gray is 12 vot. I need help on the BLACK and YELLOW. I just can't fine which wire to connect to. There is 10 wires on the head light timer 5 on top and five on bottom. I just don't know which wire to cut on the head light timer. Please help if you know. the car i have is a 89 nissan 240sx. help? help?:confused:
i heard of some wiring troubles with those. isn't the red for power and black for ground? just wondering.
doesnt the pivot set send u instructions ? i know many people have them ... check the other forums , nissaninfinitclub.net and zilvia... post there... this accessory mod is sort of common....
well the instructions are in japanese, and I know some have had problems, but I would do as malice suggested, it is good to try some others, since we seem to be of no help :confused:
The pivot unit come only in japanese instructions. Do you know any one who did it on there car or know how to wire. It also say that the japanese S13 and 180sx are useing different wire then the US version. :(
Where did you purchase it from?
If you purchased it from www.autoimaging.com they might be of some assistance. Or even if you din't you should call them and see if they can help. |
i think i might purchase that when i get my intake... i love that look.. the first meet i ever went to had like 4 guys with that setup... looked neat.. i acutally tried disconnecting my headlight switch to make it look like that... it did... but i wouldnt get light coming out of it when i had them out...
I wanted it too and still might get it if I ever get my car on the road properly, or get a s15 conversion :D
Originally posted by doua The pivot unit come only in japanese instructions. Do you know any one who did it on there car or know how to wire. It also say that the japanese S13 and 180sx are useing different wire then the US version. :( Or do you have a link? I might be able to figure some of the instructions out if I could see them. |
what is sooo good about the pivot one?
why not just manually do it.. |
because when it's raning you might not want to stand in the rain to open em up. just turn the knob and off you go.
now whats so good about it:p |
but i dont see why it really matters..
just keep the sleepy eye look all the time and just get aux lights |
Auxiliary lights are almost never as bright as the factory headlamps and also enver give the range as factory headlamps. THe pivot units allows the up and down movement of the headlights so this way you still have functionality for those dark roads.
