Help
Old 05-24-2004, 03:26 PM
baggingwagon's Avatar
Help
I replaced the head on my 89 and it runs really ruff and at about 3500 rpm there is a knock. I know its not the head knocking but i'm unsure about the valves on the cylinders The blcok was set a TDC and so was the head before i put it on so it should be timed right any ideas would be GREAT running out of ideas!!
baggingwagon is offline
Old 05-25-2004, 06:30 AM
Project Cheap13's Avatar
You didnt check the timing after the head install?
Project Cheap13 is offline
Old 05-25-2004, 02:36 PM
The timing should be close or right on because both the block and the head were at TDC. How do you check the time with a timing chain? That sounds really stupid but i guess i need help and am out of ideas maybe i'm doing something wrong? any help will be good thanks.
leiferik1
10-13-2002 08:45 PM
Quick Reply: Help
