Help me out here, just a little bit.
I have an S13. Blown KA24DE. Getting an S14 KA24DE..
What all do I have to swap over to make it work in my S13? give me a descriptive list, PLEASE. |
trust me... its all you need because i used the same info back in 05
https://www.s-chassis.com/forums/how-tos-installations-48/ka24e-ka24de-swap-40949/ |
thats for a kae not kade.
uhm................. it all applies... and that is for a kae to ka24de
AFAIK, the only differences between the S13 KA and S14 KA is
- OBDI vs OBDII (more emissions) - ECU (fuel maps are different) - Internals (S13 240/248 cams ~ S14 232/232 cams - SCV butterflies in S13 and not in S14 - No AIV PAIRS from 1994 and later I'm sure there are other little things that differ between the two. I don't know how different the body harness is from 13 to 14, but as long as you can get the ignition/starter/fuel pump wires spliced or plugged correctly, you should be good to go. |
^^ +1
nick you basically need everything from a obd1 s13 that is already listed in the list of "things needed" it doesn't get any easier bro.. im sorry. |
Originally Posted by YangpaNemsay
(Post 386315)
1991-1993 parts:
-Wiring harness (tach if you want the tach to work) -ECU -Power steering pump AND lines. -A/C compressor and lines. (unless you can make a bracket for your original one. -Distributor and coil -Intake manifold -Throttle cable/cruise cable(if you like things all nice and neat) -Extension Piece that goes from butterfly to intake piping(again, if you like it nice and neat) -MAF |
(Post 386329)
1991-1993 parts:
yes if its obd1 which yours is.... all you are doing is swapping all the s14 stuff off, however, if its a manifold without the secondary swirl valves... keep it and just swap the electronics and TB from your obd1 manifold to it. Nice little free mod.
