Heres a good one for ya....
Will the s13 AEM intake fit an s14? I have an s13 right now and might get an s14. The piping looks almost the same, its worth a try right? I think the s13 intake has three hoses instead of two like the s14...
http://www.**********/links/installs/aem-intake/032.jpg And heres mine... http://img190.imageshack.us/img190/6...0sx001a3si.jpg Notice the extra hose, I could alwalys block the third...The bends look a little different too :dunno: |
well from the pics it looks like its going to be a little short. seems like it isnt going to fit right.
Yeah I think your right...Im stillgoing to try :p Anyone else?
it's Ka24de, right? I don't see why it wouldn't if it's the same engine... if anything wouldn't the S14 engine bay be a bit bigger? I can't tell you for sure just because I've never really poked around a S13 engine bay.
well, if the s13 has a KA24E ... then it wont work .. the throttle body is higher, and the manifold is lower. If you notice on the s14 the pipe bends down before the TB, but in the KA24E, the pipe goes straight in.
The engine mounting of the s14 sits higher than the s13. If you look right at the TB the s13 curves and runs down to the TB. The s14 intake runs straight in.. Engine bay of the s14 is longer also the radiator of the s14 is also bigger.
hmmm....I have a 95 motor in my s13....i have a s13 aem intake on that s14 motor....the only thing that doesn't line up is the little mounting tab where it bolts down to the radiator support. a zip tie fixed that real quick....other than that, it works fine. I don't see why it would be any different in your case.
