hit water now 240 sounds like v8
ok well we had almost nine inches of rain a while back here in nebraska. . . well that night i was driving the 240 and a couple days before i put on a ghetto intake and where the grill thingy is i made a ram outta four inch tube with a elbo that kinda shoved air into the intake well needless to say it rained and i'm sure it scooped water into the intake. . . .well i sold the car for 500 thinking it needed an maf or tps not sure tho well the kid did nothing with it so i bought it back for four hundred because i need a car and it didn't burn ne oil or nething just needs a second gear well. . . when it idles it sounds like a v8 but when u mash it or cob it whatever u want to say it runs fine for the most part . . . but at no gas it kinda wants to die so i'm thinkin tps but what would you guys think?
huh.... v8's sound fine idling.... explain the problem more.
haha, hey whats wrong with that? Prolly sounds cool! ;)
what i say is that it idles lieka v8 like a v8 with big cams were it's lobes are making it idle funny grrrr i figured you would pick that up off of how i talked about it i can't explain it great but i mean it's like a v8 with large cam lobes is the only way i can think to explain it
check 4 vacuum leaks and check your injectors.
well hey i just hit some water so i'm figuring that it's just some ****ed up **** with some sensors so anyone that could help me out on that and have had similiar problems would help me out
have you driven it since this happened yet? You may have just sucked water into your intake, so its idling rough. But if you've been driving it, and its still doing it, then thats probably not it since the water would have burned off by then. I dont really know to tell ya the truth.:dunno:
lol this happened like six months ago and i sold it i'm thinkin it's the mas or the iac or something but i'm not sure i need a second opinion from someone else well if neone could help it would be much help
Water in engine=bad DUH! If you got water sucked into the intake, most likey your engine wouldnt be making any noise except the starter....Change your oil :D
wow it's really annoying how everyone post whores but has nothing really to say if it's gonna be a dead post let it be a dead post. . . .checked the oil for water none. . . .changed the Mass Air Flow Sensor. . . . problem solved
PLEASE CLOSE THREAD |
