horn button on momo steering wheel
I just installed a momo hub and s. wheel and know the horn don't work?? has any one else had this problem/ If so how can I fix it?
thanx for any help you guys can give. |
Re: horn button on momo steering wheel
Originally posted by dkdeleon I just installed a momo hub and s. wheel and know the horn don't work?? has any one else had this problem/ If so how can I fix it? thanx for any help you guys can give. The chassis is the ground and the button is the open. Try reversing the wires before you tighten up the wheel. |
Re: Re: horn button on momo steering wheel
Originally posted by StanBo Your green should go to the chassis of the momo hub and the black should go to the button. Or vice versa. The chassis is the ground and the button is the open. Try reversing the wires before you tighten up the wheel. but thanx for the reply.:bigok: |
