i need help
i need help
ive been having some problems out of my 92 240sx. its like when you push in the clutch and take it out of gear to turn, it will die, and whe its idleing it will bog down really low. just like to know if anybody knows what the problem is and if you know what i could do to fix it. thanks.
thatd be my guess, you can also just loosen the screw to raise the idle if you dont feel like taking it out to clean right now. the aicv is on the very back of the manifold on the bottom. its got a little screw you can adjust.
Jovan
05-30-2006 03:58 PM
PROJECT_D
12-11-2003 06:11 PM
