I think I am going to snap
I have been trying for god knows how long to locate a butterfly that I could use to replace the one in my current throttle body if I were to enlarge it to 65mm. No one, as far as I can tell, sells butterflies individually. You have to buy an entire throttle body from them. I just need the butterfly, waffer, or whatever you want to call it. Does anyone know where I can get one? If I don't find one soon I think I am going to loose it.
find a car that has a throttle body matching yours then go junkyard hopping. thats my best advice.
well i would need to find a car that comes stock with a 65mm throttle body and then try and get the butterfly from that one onto my bored out 240 throttle body.
Originally posted by adavib well i would need to find a car that comes stock with a 65mm throttle body and then try and get the butterfly from that one onto my bored out 240 throttle body. |
Off the top of my head... a Mustang 5.0 has a large throttle body I think... or was that the MAF?
Dude there's got to be a car with a 65 in it... check up on the domestic boys V8's.. getting a used TB would probably be more cost efficient too from a domestic since probably the only imports that use a 65 or > are like baller NSX's or something :thumb: |
I could be wrong but I believe the 5.8L Mustang V8 engine has a 65mm TB.
Originally posted by Jorilad I could be wrong but I believe the 5.8L Mustang V8 engine has a 65mm TB. |
ROTFL, yes, I meant to type 4.6L. Have NO idea how I typo'd that one! Anyways, the engine I'm talking about is the 32-Valve 4.6L DOHC V8 which is available in the Mach 1 and the SVT Cobra (supercharged, but same engine nonetheless). I think the SOHC 4.6L V8 has a slightly smaller throttle body.
Originally posted by Jorilad ROTFL, yes, I meant to type 4.6L. Have NO idea how I typo'd that one! Anyways, the engine I'm talking about is the 32-Valve 4.6L DOHC V8 which is available in the Mach 1 and the SVT Cobra (supercharged, but same engine nonetheless). I think the SOHC 4.6L V8 has a slightly smaller throttle body. |
Probably a good deal. :p
