Injector Problem
Injector Problem
I have a 96 240sx with all the basic bolt on's and then some. Well my car has been hard to start past couple of weeks, so i ask the Nissan online mechanic about a injector leaking which I had read about on some one else car and it sounded like my problem. Well I did the test at my fuel pressure gauge when I clamped the line had 45psi I went out to check on it about an hour later may have been a little more but it was down to 35psi. Now that I need to replace an injector I was going to upgrade talked to Mike(? I think) at Enjuku and he said the stock SR injectors are a direct bolt in and I could use a Apexi SAFC to tune it. Now if I did this would a SR fuel rail work in my car or is the spacing different? Is any one using this current setup? I plan on going KA-T. Also does any one know where i could get a set of used SR injectors? These are side mount correct? Any feed back would be helpful.
You can find SR injectors on some forums under classifieds. I see them all over the place goin for like 100 bucks or so. www.unstable-hybrids.com sells your fuel rail for 130 bucks. So about 250 bucks for injectors and fuel rail. The main thing that will get ya is the apexi safc.
Robbie
Robbie
uvamosk
08-12-2005 07:31 PM
