KA Cam Specs (S13 & S14)
These cam specs are for the 240SX Cams only, they do not apply to the Frontier or Altima. Well as we know from the Sticky Selecting your N/A KA The S13's have 240/248 Cams and the S14's 232/232 Cams. Well heres the Specs for them:
1) ’91-’93 240SX (S13) - **Note: '94 Exh Cam specs are slightly different** Int Cam = 240 Duration Lobe Height = 1.6699”-1.6774” (Int opens 1* after TDC & closes 61* after BDC) '91-'93 Exh Cam = 248 Duration Lobe Height = 1.6699”-1.6931” (Exh opens 64* before BDC & closes 4* after TDC) '94 Exh Specs Exh Cam = 248 Duration Lobe Height = 1.6699”-1.6931” (Exh opens 60* before BDC & closes 8* after TDC) 3) ’95-’98 240SX (S14) Int Cam = 232 Duration Lobe Height = 1.6699”-1.6774” (Int opens 1* after TDC & closes 53* after BDC) Exh Cam = 232 Duration Lobe Height = 1.6699”-1.6774” (Exh opens 48* before BDC & closes 4* after TDC) |
