KA Injection recommendations
so i want to run some SR injectors .
has anyone ran this set up ?? also.... i want to keep my engine N/A . soo im looking for CC recommendations any advice is muc appreciated . |
TONS of people run SR injectors on KA-Ts. They are 370cc, up from the stock 260 (?) cc ones. Just search, you will find more info. N/A is a waste though at the kinds of numbers that will need bigger injectors.
On the KA if you are going to use the 370cc inectors you will need the following...
Atleast an SAFC lobier cams and some headwork Stock 270cc injectors will make out at about 185-190WHP if your not making those kind of numbers yet there would be no need to upgrade. |
Or.. you can run 370cc injectors, not ECU or engine mods and only burn E85 through it...
Unleaded gas with run too rich... |
Originally Posted by RMS13FU
(Post 365259)
Unleaded gas with run too rich... E85 doesn't work well on our engines, it corrodes aluminum. |
Works great, been running it for a year, no adverse effects.
E85 isn't pure Ethanol, there is enough unleaded in it to keep things from corroding |
E85 FTW, more power, less emissions :)
Originally Posted by 240-kid
(Post 365870)
Ethanol isn't any better either because through the catylitic process it makes ammonia and acids. Believe me the process for bio products is no where near perfection yet. I know because I sell bio-diesel, and sell the manufacturing system to restaurants (remove there Grease). Vegetable oil is way better than pork fat, it has less triglycerides. |
(Post 365870)
Not to mention the fact that many companies who jumped on the E85 band wagon decided to use an ineffective graph to show emissions output. A Stanford research group discovered that once you put it on an actual 3D graph that is more similar to real life, E85 pollutes just as much as regular petrol does (if not slightly more) There are different forms of E85, but fact is, no one wants to spend a dime on research. Sugar cane E85 is a better alternative to corn, but companies dont really care about that. Back on subject, what are the power gains you are looking to achieve? That is also something you must look into while choosing injectors. |
(Post 365983)
There are different forms of E85, but fact is, no one wants to spend a dime on research. Sugar cane E85 is a better alternative to corn, but companies dont really care about that. Honestly brazil researchers did a study on hemp (marijuana) and found it to be the highest in energy content. Henry Ford made hemp oil and hemp ethanol to power his engines before the petroleum industry took over. In california Arnold Schwarzenegger deemed the hemp plant illegal for production, this was mostly lobbied with the petroleum, and cotton industries. |
Funny how hemp does wonders as an alternative fuel. I heard about hemp being a better alternative to cotton for making rope. Oh well, I guess big corporations will do what they need to to stay on top.
