ka with spark and fuel no flame
so i rebuilt my ka bottom end and obviously had to pull the timing chain and distributer off left the top end on marked the chain and the gear so i could match them after i had the new bearings in matched them up after i put everything in and now i have fuel and spark but no flame could i have messed the timing up???:crap:
what happens when you turn the key? will the engine turn over or not, if so is it turning over too slow, too fast? if it's not turning over, are there any noises?..ect ect ect.
we need more info. |
spinns over just fine sounds a little slow but not enough to not start i here the fuel pump and everything start up. it has all new fluids tranny to and i have spark o i have a rogue plug on the intake side that i cant find the sensor for it is a 3 wire plug
without knowing what sensor you are referring to, at this point the best i can figure is that your timing is off. you should set the engine to tdc and look over everything to make sure things are where they should be.
