KA24de starting issues
:dunno::ugh:
Im so blown like ****!! Ok me and my friend got done hot wiring the fuel pump (Brand new Walbro fuel pump) and fixing the ignition coil (brand new MSD blaster coil). Every time we try to start the car, it seems like it wants to turnover (so close). I mean the car acts like it wants to turnover, but its just not getting any spark or fuel from somewhere. Were just clueless at this point!! Yes!!! I searched btw.. |
3 Things an engine needs... Air, Fuel, Spark. Crack open the FSM. Might wanna invest into a continuity tester. Rehash what you installed (MSD Blaster) if you're not getting a spark (firing in the right order?)
bingo as sieji said.
ps sieji your sig is funny and cool but to big bro. it has to be 600 x 150 |
Originally Posted by Sieji
(Post 388345)
I was thinking it could be bad ground, ecu or wiring thou.. |
Neva mind its running now..something about codes and timing also wiring
glad to hear its up and running once again!
Just found out its knocking after 5K so Im in the process of swapping it out.
