ka24e will not turn over!!!
i just installed a msd blaster coil 2 to my 1990 240 coupe before i installed it it turned on fine, but now when i turn the key all i get is a clicking noise from the starter
i also have a blown 75a alternator fuse can that be the problem? need the help thanks!! |
Did you disconnect the battery prior to installing it?
If not you probably shorted something. I'd double check all the connections you touched, replace the fuse and try again. |
